HOW TO USE OCCLUSION
I recently made a taptoplace app and successfully,I can move object through gaze.
can i change that so I can move objects with my hand?
the second question is:
I would like to be able to place objects only on the surface of the real object to make i more real.
as for now, i can put hologramms anywhere.
What i'm trying to achieve is to give my holograms a "physical characteristics" so that they can't be place anywhere.
i saw that in the hololens academy it possibly by mapping the space first but i was hoping if there is anyway to achieve that without having to map the space first.
my project will be used in a small space like a cabinet room.
hope you can help me with that.
Optionsahillier mod
Hi @angelicaHolo,
Loading the room as an .obj is just to help you test your project in the editor. It's not necessary (or recommended) to load it on the HoloLens.When running on the HoloLens, you can start the spatial mapping observer as soon as your app begins and keep it running for as long as you like (or only turn it on/off when the user is placing an object). In Holograms 101, we keep spatial mapping on all of the time, we just don't render it unless you are moving the Origami collection.
You don't need to have a designated scanning time (we do that in Holograms 230 so that we can convert the meshes to planes and use them instead). You should be able to move holograms along real surfaces, like we do in Holograms 230, instead of allowing the user to place the object mid-air. However, if you don't allow enough time for the spatial mapping mesh to be built, there can be holes in your world. So, if the user is moving a hologram along the floor, but the floor has not been scanned completely, the hologram might fall through a hole and get stuck under the ground. This can be frustrating to the user. To work around this, you should raycast down from the object, and if you don't encounter a surface, then simply keep the object hovering at its current height.
I hope this helps,
~Angela1
Hello, when you say "without having yo map the space first" it is without using the Space Mapping or loading the room as a .obj in Unity?
@Frimy i meant without loading the room as a .obj in unity.
it sounds a lot of calculations and work for a project that will be used in a small space
Hi @angelicaHolo,
I hope this helps,
~Angela
i noticed the holes and the lag time between the air tap and object movement.
i'll try to do what you suggested.
thanks a lot!
