On Sharing Demo - How do I change the shooting sounds?
I don't understand how the files in the sounds folder are related to the files in the code. They use different names.
Hi @spinteractive,
You can swap out the audio files by modifying the EnergyOrb prefab. In the Holograms/Support/Orb folder, locate 'EnergyOrb' and then drag it into your scene. Expand 'EnergyOrb' and select 'EnergyOrb.1' In the Inspector, you should see the AudioSource component. It has a reference to the 'Energy_Laser_Fire' sound file, and that is the sound that should play whenever the projectile is launched. Change this to point to your new sound file.
On the 'Projectile Behavior (Script)' component, you will find references to two other sound files: 'Energy_Laser_Hit' (which is attached to the EnergyOrbFinalImpact prefab), and 'Energy_Laser_Deflect1'. Swap these sound files out with your own, then press the 'Apply' button at the top of the Inspector window to apply the changes to the base prefab object. After that, you can delete the instance object from your scene. The next time that you deploy you app, you should be hear your custom sounds when firing projectiles.
I hope this helps,
~Angela
Yes i found it. Thank you
