Unable to connect via WiFi after update to Windows 10.0.14393.448
I just updated my HoloLens to Windows 10.0.14393.448 but now I am no longer able to connect to the device portal via WiFi. It will only work via USB.
I'm also unable to ping the HoloLens IP address, but I never tried that before the update, so I'm not sure if that is supposed to work.
HoloLens Companion is also unable to connect.
Anyone ideas?
Mark
Seems to be working for me. Are you connecting to the internet ok from the Hololens? Are you sure you are on the same network / mask (although it would be strange for it to change after update).
This is probably similar to this post
Some HoloLens Devices need a network reset Unpair All. Some seem to need a full factory reset, but first of reset/power down your wireless router first.
You CANNOT ping your HoloLens device there is no ping port responder service, the networking is like that of a Windows Lumina Phone
Download the latest Wi-Fi drivers from the manufacturer website and install it after that:
Hope doing this will solve the Wi-Fi issue.
The given information is taken from: http://www.fixwindowserrors.biz/blog/fix-wi-fi-stopped-working-after-updating-windows-10/?utm_source=forum&utm_medium=ref&utm_campaign=bl
