Holograms
Hi there,
I've created hologram 3d model, how to build a hololens application like the following
https://www.youtube.com/watch?v=5_QcSmStr40
can anyone help me
@Jones,
Perhaps the steps in this post will help you get started.
Let me know if you have any questions.
HTH.
Thanks @HoloSheep, Please let me know the exact procedure to do it. I've tried but it's not working.
@Jones
Which step are you having problems with?
Are you getting any errors along the way?
What behavior are you seeing that is working and what behavior are you seeing that is not?
Thanks @HoloSheep, I can import a FBX object into unity and can preview it in Microsoft Hololens, But the 3D box like for other default holograms and action grams is not working. Please help.
@Jones
Can you explain what you mean by "the 3D box"?
Do you maybe have screen shots of an example of the 3D box and another screen shot of what your app is doing?
Thanks @HoloSheep! Actually, I'm trying to develop something similar to this https://www.youtube.com/watch?v=uuUvPoWOd0E
I want to Move, rotate, scale 3d objects inside Hololens. Thanks you once again.
@Jones
At this point each app pretty much implements its own set of interactions and user interface. The Holographic Academy sessions will step you through some of the basics on creating experiences that include some of these features.
However, there is no "out of the box" functionality that will give you things like a selection box around your 3D object. You will need to design and build the UI for your application to incorporate such features.
For Move, Rotate and Scale the Holograms 211 is a good tutorial for learning manipulation of your objects, however you may want to start at the beginning and work your way through all of the tutorials as they do provide you the details and exact procedures to complete each session that it sounds like you might be looking for.
HTH.
