Sharing Service as a service
nash
in Discussion
Just wanted to post that you can run the sharing service as a windows service by using the command {path}\SharingService.exe -install
I've got it running in an Azure VM and it works pretty well. A little latency but not terrible. Good enough for demos and POCS.
What it exactly this service does ? Can you use it for other codes?
I have found that Holoemulator cannot find some endpoints, When you just ping the device there is no answer from the Hololens. It s like having an internal firewall. I just thought maybe using this to enable some ports..
@nash sounds great. Could you please share some of the steps on how to get this up and running?
Alex
Hello,
I want to know how I can install sharing service on Live IP and consume it as the port 20602 is not reached from tcp. Can anyone help me please?
Thanks in advance..
