Stop mesh updates to a space for several days
Is there a way to temporarily stop the HoloLens from updating a saved space for several days? I'm trying to do an experiment where I want to make sure that certain 3D locations are exactly the same across multiple uses of the app. I know that you can stop updates via a SurfaceObserver, but that's only for that instance of the app. Can we stop a Space from being updated?
My current approach is to just use WorldAnchors for saving certain 3D locations. But I'm wondering if there's a better way (e.g., with trying to stop the saved space from updating).
I have no idea if this works i just breafly skimmed the code but how about you save to mesh to the disk from your app, and load it once you restart the app?
https://github.com/Microsoft/HoloToolkit-Unity/issues/188
