is using the sharing service on a non-local network possible?
All I can find online is that two hololens can connect to a computer via the sharing service on a local network. Nothing is ever said about a remote network/server hosting the sharing service. Is there a way to implement this
    We've tested running the sharing service on Azure, and that works.
    @Patrick Can you elaborate a bit on your setup? What service did you host it on within Azure and how did you integrate with that service? Thanks!
    @Patrick Even i would like to know that how to transfer the hololens data to remote client via Azure. Thnaks!
    How can we host Sharing Service on a server with live IP and connect it? I have tried but don't have success yet.. If anyone knows then please help.. Thanks
    How did you do that with Azure? Can you describe that step by step?
    I second that. Any word on how to do this?
