scaling one side of object
felsiska
how do I drag and scale only one side of object using navigation gesture? tried using same logic of navigation to rotate but only make object into flat piece of plane.
thx in advance!
OptionsHoloSheep mod
@felsiska
Did this turn out to be the same issue as this other question? Or are you looking to do something different here?If it is the same, and if the issue is resolved, it would be good house keeping to mark them both as answered.
If it is a different question, maybe you could explain further or provide an image or two to help others better understand what you are asking here.
THX.
@felsiska
THX.
