Hololens and Data Distributed Service (DDS)
Hello together,
has some one of you experience using the hololens and DDS? I would likely install an DDS Application on the Hololens to connect it with my current "DDS Network".
I found nothing how I could install normal applications on the Hololens. Only Apps/Universal Apps. Is it possible?
Greetings
Tim
@TiFra
Not sure about your DDS application and the options to build a UWP version, but...
As mentioned in the docs, the HoloLens runs the Universal Windows Platform and UWP apps.
So no, traditional/classic Win 32 desktop apps will not run on the HoloLens.
Too bad. But thank you!
