Trouble with Voice Commands in Hololens
TRR
I followed the steps from the Hololens tutorial for incorporating voice commands. I seemed to have gotten it to work once, but it has stopped working since. When I run "Start without Debugging," it wasn't working, so then I tried "Start with Debugging" and was getting an error and the application exited. I checked to make sure that the microphone capability is on and it is. Any ideas as to where I may be going wrong?
@TRR,
"Start with Debugging" and "Start without Debugging" are custom commands? It sounds like the speech commands might be working fine but throw an error when it hits the underlying code you are trying to run -- perhaps depending on your debugging environment.
@james_ashley Sorry I wasn't clear - the Start with Debugging and Start without Debugging are in Visual Studio.
But I figured it out - I wasn't connected to the internet - it's working now!
Coolio.
