Is it possible to cast my laptop's screen on hololens?
chiddaan
I know that it's possible to cast the user's point of view on other screen, but what if
I want to cast my laptop's screen on hololens? (the other way around)
Can I connect a video stream of some camera(from a http ip address) on to hololens?
If yes, can I map the movement of user's head to navigate camera left and right if the camera has capability to move left and right?
I am at a very initial stage of my project, so just trying to know about possibilities.
Not looking for exact solution on "how to", just the possibilities for "can we".
Optionschiddaan ✭
That's a great way to start off.
Thanks a ton
I will be starting my project thread for this one.
(one thread per project, one project per thread)
@chiddaan,
There's no built-in way to do this with the HoloLens SDK. It sounds like a cool project and you might be able to pull it off with your own custom streaming solution and some servos to control the camera angle. Good luck!
Thanks a ton
Hi @james_ashley
Can you suggest the best computer system I should buy for developing applications that would satisfy all the hardware requirements?
I am a graduate student and I am starting my development work soon. So I need to know which is best out there.
Thanks.
The Surface Pro 4 and Surface Book are really nice for doing on the go HoloLens development. I use a Surface Pro, myself.
Great!
Which one of these would you recommend?
https://www.microsoftstore.com/store/msusa/en_US/pdp/Microsoft-Surface-Pro-4/productID.5072641000
Can you simply point me to the specific product?
hey @chiddaan, I'm using the Surface Pro Performance base for Holo dev and it works great so far.
Thanks Even I have a good config PC as of now, I am soon going to get high end Alienware for processing hi-fi 3D holograms :P
Did you ever get a result out of this ^ I have been looking evrywhere for a suitable fps streamer from my pc to catch a game of star citizen anywhere I please
Thx !
