Is it possible to cast my laptop's screen on hololens?
chiddaanchiddaan
edited December 2016 in Questions And Answers
I know that it's possible to cast the user's point of view on other screen, but what if
  1. I want to cast my laptop's screen on hololens? (the other way around)
  2. Can I connect a video stream of some camera(from a http ip address) on to hololens?
  3. If yes, can I map the movement of user's head to navigate camera left and right if the camera has capability to move left and right?
I am at a very initial stage of my project, so just trying to know about possibilities.
Not looking for exact solution on "how to", just the possibilities for "can we".
    @chiddaan,
    There's no built-in way to do this with the HoloLens SDK. It sounds like a cool project and you might be able to pull it off with your own custom streaming solution and some servos to control the camera angle. Good luck!
    Hi @james_ashley
    Can you suggest the best computer system I should buy for developing applications that would satisfy all the hardware requirements?
    I am a graduate student and I am starting my development work soon. So I need to know which is best out there.
    Thanks.
    The Surface Pro 4 and Surface Book are really nice for doing on the go HoloLens development. I use a Surface Pro, myself.
    Great!
    Which one of these would you recommend?
    https://www.microsoftstore.com/store/msusa/en_US/pdp/Microsoft-Surface-Pro-4/productID.5072641000
    Can you simply point me to the specific product?
    hey @chiddaan, I'm using the Surface Pro Performance base for Holo dev and it works great so far.
    Thanks :) Even I have a good config PC as of now, I am soon going to get high end Alienware for processing hi-fi 3D holograms :P
    Did you ever get a result out of this ^ I have been looking evrywhere for a suitable fps streamer from my pc to catch a game of star citizen anywhere I please ;)
    Thx !
