Hololens apps file extension
I have developed a sample application using Unity. I imported the solution to Visual studio.
I deployed my application in hololens also.
1) In file explorer of desktop , Where can i find my solution file of my application?
2) What is the file extension of my app?
3) Iam working on 1machine where my entire application is residing on. How to share the application from 1machine to another machine?
Please help me out.
Thanks in advance :)
  • @Aishwarya_Chola123
    HoloLens apps are UWP apps.
    You can familiarize yourself with the UWP app packaging process.
    In particular it sounds like you might be interested in Creating App Packages and Sideloading them onto your device through the Device Portal.
    If you are talking about moving the project files from one dev machine to another dev machine, if you Built to a new App folder inside the Unity Project folder as suggested in the tutorials and documentation, you should be able to copy the entire Unity project folder to another machine and rebuild there. Note: due to file path dependencies, you may need to delete the generated folders and rebuild from Unity on the new machine.
    HTH.
  • Thanks @HoloSheep
    It worked. I was able to create package so that i could share the application from 1 machine to another.
    How to install my application in hololens app store?
    You should find the info you need for submitting to the store here.
