How to use handles to scale like in the hologram app
i want to create a box around an 3d object like in the hologram app to scale. With an Air-Tap I will be possible to drag and the object is getting bigger or smaller.
How can I realize that in unity?
Thanks
Pad
    Hi @DragonValor ,
    I search exactly the same? Are you got any results?
    I'm looking for a solution now quite a while.. some discussions and scripts, but not a real solution yet...
    any update available?
    Not so hard but really takes a while to implement. Manage several points and make them draggable; when dragging change the object and other points as well. Cubes and spheres is enough.
    Thanks Civitas, however, I'm really looking for a step by step approach with scripts....
    I want the same funs. Can we intergrate windows tile to implement this?
    like some plugins.Looking forward to the reply and implement of some one.
    You could use the App Bar and Bounding Box from the MR Design Labs
    https://github.com/Microsoft/MRDesignLabs_Unity
