HoloLens Emulator does not load W Store HoloLens app due No Windows Update
When trying to load RoboRaid from Windows Store Made for HoloLens I got error
0x8007007E from the Store. The Answers says Reset windows update setting, register Windows Update engines and do famous WSRESET. Well of course if we had PowerShell we might.Studying portal processes none are running so I assume that Emulator cannot load Windows Store apps. Just need someone to check the real physical HoloLens does?
EdAM ✭
I have been talking about the emulator, so the answer that they do not support store apps yet explains things. It would have been nice for this to be published or at least provide a better error than they do today.
Any timeline on when they will support this. We want to try out the Skype app, since we cannot get a device for several months...
5 -
Jimbohalo10 ✭✭✭
This thread started just after HoloLens Emulator and in it parts Windows 10 was released.
Now Windows 10 Anniversary (build 14393) and the updated emulator has been released. Some HoloLens App on the Windows Store can be loaded and work.This does not means that for instance that apps that rely on Spatial Mapping will work because the HoloLens RGB CAMERA AND CODE DOES NOT EXIST.
Many Holograms require other code residing on the device and wont work.
Please remember that an app must be installed _EVERY TIME THE HoloLens Emulator is STARTED.
They are temporary and transient, if an error occurs due to missing bit of code _DONT bother trying againMany standard apps will load and the main reason is because you need to run the HoloLens Emulator in Administrator "Run as Administrator" and this is done by starting from Command shell in Standalone Mode NOT via Visual Studio start-up.
DISCLAIMER
This is not an officially Microsoft supported answer but a workaround for the HoloLens Emulator, and any damage resulting in corruption and consequential reloading for the PC or any code as a result is your correcting “responsibility”I have documented this in detail in
How to install HoloTour on to HoloLens emulator0
I am experiencing the same problem and with all of the Store apps in the emulator. Tried on two different machines.
@EdAM did you try loading apps from the store from an emulator on two different PCs or did you try loading apps from the store on two different actual HoloLens devices?
I am also seeing the same error number when I try in the emulator, but I haven't found mention anywhere yet if anyone has been successful with loading store apps into the emulator or not.
The emulator does not currently support MSA sign in.
@neerajwadwa considering the emulator's current limitation of not supporting store downloads, are there appX packages available for the launch titles that we could side-load into the emulator?
I would also like to know how I can run HoloLens apps in the emulator (all relevant apps available in the Windows Store)
so why on HoloLens emulator have store apps? -_-
DISCLAIMER
