The emulator is unable to create a differencing disk when launching it directly
I launched the hololens emulator directly using the command prompt.
https://forums.hololens.com/discussion/236/running-emulator-directly#latest
I get the following error.
the emulator is unable to create a differencing disk. The system cannot find the path specified.
Also I can't create a Holographic application in Visual Studio, I get
Emulator Deploy Error DEP6100 Cannot access a disposed object. (another thread:https://forums.hololens.com/discussion/comment/5226#Comment_5226)
Please someone help me.
PS. the folders containing the .vhd files are not compressed or encrypted.
Try mounting the Virtual disk to see if there is a problem using PowerShell Running as Administrator
PS C:\WINDOWS\system32> cd "C:\Program Files (x86)\Windows Kits\10\Emulation\HoloLens\10.0.14342.1018"
PS C:\Program Files (x86)\Windows Kits\10\Emulation\HoloLens\10.0.14342.1018> dir *.vhd
Mode LastWriteTime Length Name
-a---- 19/06/2016 11:25 1477242880 flash.vhd
Now try mounting this virtual disk
PS C:\Program Files (x86)\Windows Kits\10\Emulation\HoloLens\10.0.14342.1018> Mount-VHD flash.vhd
Check the new drives for corruption
I don't know what else there is to start the Emulator, but to go into Control panel and uninstall
The reinstall the HoloLens Emulator
Did you launch from an elevated command prompt?
Yes
Windows Start icon > Windows Power Shell >Windows Power Shell(x86)
Right Click "Run ISE as Administrator"
Click "Yes" to the Run as Administrator modal prompt
or Windows Command prompt Right Click "Run ISE as Administrator"
Not sure if this is a requirement, but are you a member of the "Hyper-V Administrators" group on your PC?
Might be a little bit late on this, but got this error whenever tried to launch the emulator from Visual Studio - emulator launched, but the user and keyboard input were disabled and got the error message:
"Severity Code Description Project File Line Suppression State Error DEP6100: The following unexpected error occurred during bootstrapping stage 'Connecting to the device '4CE3B45E-0530-04A7-0B7F-F404E7D5D220'.': ObjectDisposedException - Cannot access a disposed object. Object name: 'XdeServiceClient10_0'. [0x80131622]"
Was finally able to correct it when uninstalled the emulator and the Windows Software Development Kit (for W10), and then reinstalled both but checked the flag 'Send anonymous usage data to Microsoft for the Windows 10 Kits'. Before doing this always got the error and was unable to use the emulator.
I though we were supposed to be able to chose to send or not...
Really useful?Has anyone tried this method?
