Spatial Mapping Doesn't Work when running on Target Hardware Holographic
When building out a Holographic application in Unity 3D and deploying it to the Hololens Simulator, if I follow what the documentation suggests as best practice and change the Package app manifest property of the target platform from Windows.Universal to Windows.Holographic then Spatial Mapping no longer works. I am not sure if this is an issue with deploying to just the simulator and that it works correctly on devices, but I would like to know if anyone else has run across this issue, or if I am doing something incorrectly. Thanks!
    RussellRussell
    edited April 2016
    Hi okhan80,
    I just tested and it looks like this is occurring on both device and emulator.
    For now, the simplest mitigation seems to be updating the MaxVersionTested field to be 10.0.10586.0 instead of 10.0.10240.0.
    Doesn't work:
    MaxVersionTested="10.0.10240.0"
    Works:
    MaxVersionTested="10.0.10586.0"
    Russell
    @okhan80, Also be sure that the Spatial Perception capability is set in your application's manifest.
    You can do this either in the package.appmanifest file, or in Unity by selecting the SpatialPerception checkbox in the Player Settings.
    Set SpatialPerception capability in the package.appmanifiest file
    Set SpatialPerception capability in Unity
    David
