How do I get the location of a SpatialAnchor?
Hey,
I have a 3D DirectX Holographic app that is using spatial anchors and I was wandering how I could get the Vector3 coordinates of the SpatialAnchor.
The spatial anchor is coming from Windows.Perception.Spatial.SpatialAnchor
This is all in C# and I have tried using the SpatialPointerPose
to get the HeadPose
and get the position off that but that is the position of the HoloLens and not the position of the SpatialAnchor. I only tried the HeadPose because it was the only way I could find that would give me a position.
I have had a look into the SpatialAnchor.CoordinateSystem
but could not find a way to get the Vector3 coordinates.
Any help is greatly appreciated!
Took it upon myself to solve this myself.
//ugh I hate this forum's code formatter.//////////////////
`float3 SpatialAnchor::getCurrentPosition() { if(anchor) { auto trans = anchor->CoordinateSystem->TryGetTransformTo(baseCoordinateSystem); if(trans) { auto mat = trans->Value; //Windows::Foundation::Numerics::transpose(trans->Value); //all we care about here is the position float3 pos(mat.m41, mat.m42, mat.m43); lastValidPosition = pos; return pos; } else { verr << "Warning: unable to get most recent transform from spatial anchor" << endl; return lastValidPosition; } } return float3::none; }
I haven't looked into all the SpatialAnchor code yet, however if you have the position of the HoloLens, when it is hit testing/ collinding with your hologram, then you effectively can calculate the position of the anchor. You have an Up vector, and a surface normal vector. Anytime you have at least 2 you can orthogonally calculate the 3rd, which in this case is the X vector you're looking for to get the coordinates. By getting the cross product of the UP and Normal vectors you get your X vector, hence your position in space where the Hologram is. Is this what you're looking for?.
Dwight Goins
http://dgoins.wordpress.com
//Creates an anchor at the origin of the specified coordinate system.
public static SpatialAnchor TryCreateRelativeTo(SpatialCoordinateSystem coordinateSystem)
//Creates an anchor at a specific position within the specified coordinate system.
public static SpatialAnchor TryCreateRelativeTo(SpatialCoordinateSystem coordinateSystem, Vector3 position)
//Creates an anchor at a specific position and orientation within the specified coordinate system.
public static SpatialAnchor TryCreateRelativeTo(SpatialCoordinateSystem coordinateSystem, Vector3 position, Quaternion orientation)
More info: https://msdn.microsoft.com/en-us/library/windows/apps/windows.perception.spatial.spatialanchor.aspx
Thanks for all the replies. I haven't continued on this project since this question but I may be jumping back into it soon so I will post my reply as best I can.
I should have added that these spatial anchors were coming from the WorldAnchorStore
UnityEngine.VR.WSA.Persistence.WorldAnchorStore
so they are already created hence I can't get them from the position when creating them.
As for your answer @mlfarrell, I believe that is in C++ and I mentioned that I am doing this in C# but I will set that as the answer for now and check on it when I get back to my project and convert it to C#.
