Is update 1 or update 2 required for Visual Studio 2015
ResidentxResidentx
edited April 2016 in Questions And Answers
It says 2015 update 2 but I can only get update 1, https://developer.microsoft.com/en-us/windows/holographic/install_the_tools
    ResidentxResidentx
    edited April 2016
    Can't delete post....
    I had to UNINSTALL from Control Panel VS2015 update 2 RC. Basically the download in the link is VS2015 Community and if you watch adds a section call 2.1(beta8) in the UWP library, which does not exist in the incremental updater. From Update 1 to Update 2. Hence you have to uninstall your Community version and install fresh 20th March version.
    VS 2015 Professional and Enterprise do NOT have these updates, and in this case make a new partition and install Win 10 from the ISO kit 14291. Then install as per instructions in the link
