Connecting HoloLens to Sharing Service
sbagchi
Hi all, I've been struggling for a while, but I'm still unable to get the HL connected to the sharing service. I'm able to connect when I run my scene in Unity, but not otherwise (through HL or emulator). I had thought there was a firewall issue at work, but I've since gotten an exemption and put in rules for the service & port (20602). Can anyone think of something else I should try?
Some context - I only have one HL, but can borrow another if absolutely necessary. I'm only trying to connect one HL to my pc for the purposes of sending data to and from another Visual Studio project. If there's a better way of doing this that would avoid the sharing service, I would be interested to hear it!
Need more information to get your problem. Where have you installed service? Are your Server, PC & HL in same LAN? Have you properly given Server IP & Port in Sharing Service object in Unity?.... etc.
I have also got the same problem and its resolved by providing Live IP. Also I believe that Sharing Service should be installed on third System (Server) then PC.
I managed to solve it. Some additional firewall rules needed to be adjusted!
Hello @sbagchi I'm having the same problem, which firewall rules exactly? the ones for the sharingservice.exe ? did you set it to local, private and public networks?
You can do it in powershell:
