Enable and disable a custom recognizer
Frimy
Hello,
I created a custom recognizer with a TappedEvent in the Start() function of my script:
void Start() { recognizer = new GestureRecognizer(); recognizer.TappedEvent += Recognizer_TappedEvent; recognizer.StartCapturingGestures(); } private void Recognizer_TappedEvent(InteractionSourceKind source, int tapCount, Ray headRay) { //My code }
My problem is that the function Recognizer_TappedEvent is called even when I did not break in my Start() function. I want it to be active when the script start and to be disabled when I disable the GameObject containing the script.
I though about using a boolean, but I guess there is a method much cleaner to do that.
Thank you in advance everyone!
OptionsS_Lincke ✭
Just deregister your handler when the object gets disabled:
void OnDisable() { recognizer.TappedEvent -= Recognizier_TappedEvent; }
Just like that you can reenable it again in OnEnable if you need to.
1
It did the trick, thank you very much!
