Application stalling with "Made In Unity" screen
Sometimes my Unity Application will suspend and go to the Unity start up screen ("Made In Unity" screen) and suspend my application. I think this is happening because the device is loosing tracking - I can make it happen by looking at the floor and rotating.
Is this a known issue, any work arounds? Is there a way for the application to NOT suspend, but carry on, even if tracking is lost?
Cheers
OptionsS_Lincke ✭
File -> Build Settings -> Windows Store -> Player Settings
then, in the inspector, choose Splash Image, and towards the bottom you have "On Tracking loss pause and show image".
1
@kidsmurf2000 , does this throw an error or does your app just freeze? Are you using the Spatial Understanding prefabs?
Perfect, thank you!
