How to get visual Meshes
Hi Guys,
I'm using the Spatial Mapping example from the Holograms 230 tutorial to create a mesh of the room. How can I get only the visual meshes, so the meshes that are currently in the field of vision?
My goals is to create a "heatmap" that indicates the distance between different surfaces and the user.
Hi @CornKrue, you should be able to use the position that you are currently looking at by using the cursor/gaze and then looking through all of the spatial meshes, from
SpatialMappingManager.GetMeshes()
and look at theMesh.vertices
which returns an array of Vector3. Then I would get the average of those and find the distance from your cursor to that average and only display meshes that fit your required distance.
