UNET Master Build not working
raj9
I have a project that connects multiple hololens devices with UNET. The release build works fine. But building on master causes connection issues. I am using network discovery and networkmanager HLAPI components and I was able to pinpoint the issue to the fact that when ever networkmanager and discovery are started together, it causes abnormalities (I'm not able to connect to the server). When I introduce a delay between the Networkmanager.singleton.StartHost() and _networkDiscovery.StartAsServer() things work "better". Any ideas to why this is happening ?
Let me know if more info should be added to explain this better.
I stumbled upon the same issue as you. Also found that StopBroadcast() needs a frame delay as well. I submitted a PR into HoloToolkit-Unity that fixes the UNET shared experience example with the work-around I put together. Here's the PR: https://github.com/Microsoft/HoloToolkit-Unity/pull/492
