Connecting to webservice
Hi
I have to connect with webservice to get some values online.
I use this code :
IEnumerator Download()
// Pull down the JSON from our web-service
WWW w = new WWW( "url" ); yield return w;
it works in unity but when I run the app in hololens emulator the result always returns empty "".
Any help?
Thanks
look for w.text
Also check if you are receiving a 404 or if you have cross domain issue.
If its a rest service you might want to look at WWWForm and post the data WWW(url,data,headers)
markval.com - All around Digital
No
always w.text=""
but when I run the app in unity, it works perfectly
Are you using localhost?
Look for w.error then. If you are receiving some data you might want to check to progress and bytesDownloaded.
https://docs.unity3d.com/ScriptReference/WWW.html
What's your server? Are you using Post or Get? Is it a socket?
It is an online webservice. it just returns simple json string (just for testing).
It is GET.
It works in Unity . just string
I have to add Capability (Internet)
This is in the Package.appxmanifest file --> Capabilities Tab.
