I am unable to connect the HoloLens Companion App to my HoloLens on home wifi network
I am unable to connect with the HoloLens Companion App running on my Win10 PC. On the HoloLens, both Developer Mode and Device Portal are turned on, and I created a User Name and Password via WebB previously. The IP address is correct, AND I was able to connect using Internet Explorer and typing in the IPv4 address (10.0.0.43). Via WebB I was able to view the MRC live view, examine the IPD, etc.. However, the HoloLens Companion App comes back with a FAIL on every attempt to connect.
Any suggestions?
Sounds like you've done everything I can think of trying off the top of my head -- know that it worked for me first time ( even blogged my experience http://bit.ly/HoloLanceOnline ) -- next thing I'd be interested to see is if it would work on another wifi network? Interested in how this works out for you - if there's anything I can do / verify to assist with my working setup - let me know.
//Lance Larsen | www.lancelarsen.com | @lancelarsen | 608.31LANCE
//HoloSoft | holosoft.net | @holosoftnet | www.facebook.com/holosoft.net
//MADdotNET President | maddotnet.commaddotnet
Thanks Lance,
In your link, you mentioned that after entering your IPv4 address, you added your username and password. Were IPv4 address, user and password all on the same line shown in screen capture, or did another dialog come up for entering username and password?
Brian
