How to adjust Hololens Opacity?
changgyu
in Discussion
While I was playing with Hololens Unity samples with my device, I do not remember what I did exactly, I noticed that the opacity of hololens is very transparent and I can barely see any holograms, menu and apps. I am resetting my hololens because I couldn't find any option to adjust the opacity of hololens. Is there any way to adjust the opacity of hololens?
Quick update... After resetting, I get my proper opacity back...
@changgyu,
I believe what you may have experienced was the brightness (the buttons on the left arm) being set either very high or very low.
When you reset the HoloLens, it restored the initial default brightness value.
David
I did have the brightness buttons stop responding for me once, but a restart fixed that.
Maybe You need to Restart it.
Microsoft exam dumps 70-410 (updated)
