Vuforia VuMark in HoloLens
Does anyone have a working sample of Vuforia VuMark in HoloLens?
We can't seem to get it to work. Even though the sample projects from Vuforia work fine, our own apps don't seem to recognize the VuMarks.
jbienzms mod
I do not, but I recommend closely comparing the sample and your own if the samples are working.
Are you able to get other Vuforia features working? Like image tags? If not, definitely check to make sure you've enabled the Camera capability.
Our Holographic world is here
I work in Developer Experiences at Microsoft. My posts are based on my own experience and don't represent Microsoft or HoloLens.5
This is something we just started playing with and we were able to get the Vuforia-Hololens sample program to work. (the one with the image targets with 2 tea pots). One thing I read is that the image target has to be the same size in the editor as it is when printed on paper. I expect the same goes for the vumarks. We'll be checking this out soon, but would love to know if you figured it out and have any lessons learned.
Terribly sorry for the late reaction. We finally succeeded in creating a working VuMark, we discovered that our AR camera wasn't connected to our Main camera.
After that we succeeded in showing our custom models on our custom VuMark. The size on which it operates best however is something we'll have to find out. We tried several sizes but light conditions seem to alter the outcome.
@Destros Would you mind show us how you made your custom VuMark works on your custom marker? Or you can share your package in Github?
I am still struggling with this...
