How to toggle the visibility of a group of objects
in HoloStudio
I want to create 2 collections each of which contains several object. I want to toggle the visibility between each other.
I want to give a command to speech manager and change toggle the visibility between each of the groups.
After creating these collections in Unity, I don't know even how to get access to them in c# code. I only know I can broadcast message to them and trigger the callback functions.
Thanks.
What code do you currently have?
Do you have the speech manager all set up?
What have you tried in terms of toggling the visibility?
I would recommend trying this:
GameObject collectionToToggle = GameObject.Find("nameOfCollectionGameObject"); //To make invisible collectionToToggle.SetActive(false); //To make visible collectionToToggle.SetActive(true);
Thank you for your reply. I worked it out.
Part of your code is right, but
GameObject.Find function can only work for active objects. So it needs another way to work around.
For example, I associated member variable with components in Unity to make it work.
