What exactly is NuGet and can I get around its package restore without an internet connection?
I'm trying to build an app for hololens. I have a PC with Windows 10, Unity 5.5.1 and the needed Unity packages to build for hololens. However, when i try to build the project, Unity throws an error "Failed to restore NuGet packages". All the solutions I have found on google related to this issue say to "be sure your internet is connected" but due to company policy, I can't connect this PC to the internet. I don't really know what NuGet is and Is there a set of files I can download on a different pc and transfer, or some other way to get around this error?
OptionsAmerAmer ✭✭✭
Nuget is library distribution/sharing platform. Pretty much if you want a library built by somebody added to your project, instead of having to copy dll's and adding references, it does it for you. Because nuget packages are hosted by a server, you have to connect to it to get them. If you copied the solution from another computer that already downloaded the packages, there is a nuget folder that caches all the previously downloaded packages in the solution. You can right click on your solution and go to Manage Nuget packages for the entire solution. If a package is not necessary for what you're doing you can remove it here. More than likely you need the package, so internet connection is going to be necessary
Developer | Check out my new project blog5
