Run Unity 3D app in background
I have a 3D app built in Unity for hololens, which implements Unet with client and host behaviour. The problem is, every time I suspend it (by making a bloom, f.e.), network part stops working. Is there a way to make my app run in background so I won't loose network behaviour and continue to receive network messages?
  • Go to player settings.
    Click on Resolution and presentation.
    Make sure Run In Background is checked.
  • edited February 2017 Answer ✓
    Tried already, not enough. Server stops listening and client disconnects. I found another solution, you just need to use https://docs.microsoft.com/en-us/uwp/api/Windows.ApplicationModel.ExtendedExecution.ExtendedExecutionSession in your network manager class.
    Here is a good example of it: https://github.com/Microsoft/Windows-universal-samples/blob/master/Samples/ExtendedExecution/cs/Scenario1_UnspecifiedReason.xaml.cs#L81-L110
    After I implemented Extended Session, everything starts to work fine: Server is listening, client is connected, NetworkBroadcast sends broadcast messages (checked in Wireshark). It might sometimes cause a little problem, for example, if you sent Messages with position, after resuming you can see the Hologram changing position step by step, but not immediately.
    Anyway, it satisfies our needs
  • Wow @AkhmetovTA, impressive research work. I honestly thought this wasn't possible. I've captured your notes and bookmarked this in case I have a customer who needs it. Kudos!
    P.S. I'm assuming this is still governed by the total running application cap, right? Meaning if you try to launch a 3rd or 4th app this process is still eventually suspended correct?
    Our Holographic world is here
    At first I was thinking about implementing background Task class (used to work with them on XAML XBox app two years ago), but then found this. Actually, I'm going to try Background Task few days later.
    Haven't figured yet to be sure 100%.
  • @AkhmetovTA did you ever try the background task approach? If so, which approach did you end up favoring?
  • @AkhmetovTA I'm currently building a Hololens Unity app that also uses UNET. I've implemented ExtendedExecutionForegroundSession. This stops the multiplayer sessions from breaking down after a quick bloom or the Hololens losing it's spatial mapping, but it seems to stop working after around 25-35 seconds if the application is minimized (the client gets kicked out of the networked session). Did you also encounter this issue?
    The extended background task time capability mentions a 25 second time limit, and I added that restricted capability to my manifest, but that doesn't seem to do anything (on its own).
    I've been googling a lot, but this forum topic is pretty much the only resource I've found on this issue. @jbienzms Perhaps you have found some more resources?
