Prevent HoloLens from going to sleep
Is there a way to disable HoloLens from going to sleep. On device portal, I can only choose when will HoloLens go to sleep, but I cannot disable it.
I have a problem because it goes to sleep while my application is active.
OptionsDaTruAndi ✭✭
In the device portal you find the following settings.
Sleep settings
When on battery, go to sleep after
When plugged in, go to sleep after
By default that is
2 minutes, 3 minutes, 5 minutes, 10 minutes, 20 minutes, 30 minutes.I believe you can "hack" the corresponding seconds (see below) in the "inspect" mode of the browser (or set it through code) to other values.
I set it to "0" for fun (when plugged in) and I BELIEVE it does not go to sleep now. (Update: running for a few hours now connected - not going to sleep)<select id="systemDCStandbyTimeoutControl" class="inputField"><option value="120">2 minutes</option><option value="180">3 minutes</option><option value="300">5 minutes</option><option value="600">10 minutes</option><option value="1200">20 minutes</option><option value="1800">30 minutes</option></select>
<select id="systemACStandbyTimeoutControl" class="inputField"><option value="120">2 minutes</option><option value="180">3 minutes</option><option value="300">5 minutes</option><option value="600">10 minutes</option><option value="1200">20 minutes</option><option value="1800">30 minutes</option></select>5
I believe (though I'm not positive) that the device will not sleep when the Visual Studio debugger is attached. I understand it is going to sleep while your application is active, but are you saying it's going to sleep when someone is using the device? That shouldn't be happening. If you're saying it's going to sleep when they take the device off and set it on the table, that's by design. Is there a reason you don't want this to happen?
Our Holographic world is here
Sleep settings
By default that is
Sleep settings
By default that is
It does not go to sleep while debugger is attached, and it also does not go to sleep while someone is using it. But as you said it goes to sleep while it is on the table.
I don't want it to go to sleep because it is connected to my server and sending data, and I am doing tests on server application and need HoloLens to stay awake.
@DaTruAndi
Thank you for your answer. I will try your method.
@Xarthisius Did that work for you?
yes, it works
http://127.0.0.1:10080/api/power/cfg/SCHEME_CURRENT/SUB_SLEEP/STANDBYIDLE?ValueAC=0&ValueDC=0
http://127.0.0.1:10080/api/power/cfg/SCHEME_CURRENT/SUB_SLEEP/VIDEOIDLE?ValueAC=0&ValueDC=0
after testing, it's the above post request that will set the hololens to "non-sleep" mode.
Above is what you should have after the configuration is set successfully(you have to login first and then send this request, you may consider using
postman
)http://127.0.0.1:10080/api/power/cfg/SCHEME_CURRENT/SUB_SLEEP/VIDEOIDLE?ValueAC=0&ValueDC=0
try these two post requests after connected to your hololens.
The following is one easy way to prevent HoloLens from going to sleep when it is plugged in.
Here we are actually using WDP REST API.
ValueAC
represents setting when plugged in andValueDC
represents on battery. When it's value set to0
, it means never go to sleep.Please note it's not recommended to set
ValueDC
to0
and you should only setValueAC
to0
when you really needed.
