DictationRecognizer completed unsuccessfully: UnknownError.
Trying to get the DictationRecognizer to work, but keep getting this error.
Anyone else use this successfully?
Stephen Hodgson
HoloToolkit-Unity Moderator
    edited February 2017
    Assuming we're talking about Unity do you have all the Capabilities enabled in the Build Settings? Namely Microphone?
    of course.
    I also ensured that "Get to know me" is enabled on the devices privacy settings.
    Stephen Hodgson
    I did the usual checks. Everything is configured correctly, but still getting this error.
    I wrote this class a long time ago, and I know it used to work.
    Stephen Hodgson
    If it worked and now suddenly doesn't without anything else being changed my only suspect is the HoloLens update that's somehow incompatible with your current Unity version? Just speculating here, really.
    That's why I asked if anyone else was experiencing this problem, to try and work that hypothesis out.
    Stephen Hodgson
    A vote down for a suggestion?
    You had suggested the same solution it after I told you I had tried it.
    Stephen Hodgson
    Microphone and InternetClient are not the same Capabilities. You did not tell us you which specific Capabilities you tried, you told us "of course". To my opinion InternetClient is a rather unobvious capability required for the dictation and one could easily overlook it being unaware of how the feature works. I must admit you may have had it in your head, but you didn't express it and no one can read thoughts that I know of. I didn't give up and continued trying to be helpful. You down-voted my intention. I request you kindly to remove your down-vote now that my explanation cleared the air. Thank you.
    Hey guys, there's a lot of negativity here. Especially for someone trying to be helpful. Please everyone be respectful. @stepan_stulov I up voted your recent response and I appreciate you trying to help. If I could remove all the rejected answers I would but unfortunately I don't see a widget to do that.
    @stephenhodgson it sounds like this script you are using has been around for a long time. I'm not having any issues on the current bits from the toolkit, but DictationRecognizer isn't part of the toolkit. It actually ships with Unity. I'm using Unity 5.5.1f1 and I haven't upgraded. Have you tried rolling back to a previous Unity build?
    Our Holographic world is here
    P.S. you probably already know this @stephenhodgson, but in Visual Studio make sure you've got "Just My Code" turned off and that you're doing Mixed Mode debugging (both Managed and C++). Admittedly it's a long shot, but maybe you can catch an exception message from Unity's unmanaged code this way.
    utekaiutekai ✭✭✭
    If it's possible for you, I'd recommend to use the Windows APIs directly rather than trying to use the Unity implementation. You might not have this route available due to other considerations. However, the Windows APIs are nicely done and rather easy to use once you get a good code pattern in place for what you need to accomplish.
    I use a dictation recognizer in a hololens app and it works fine and continues to work nicely with hololens software updates. See https://docs.microsoft.com/en-us/uwp/api/windows.media.speechrecognition .
    I bypassed entirely the Unity implementation of dictation recognizer, as it wasn't well presented to the developer via the API and wasn't performant enough for my needs as it seems to do intermediate buffering and inserts delays that add up.
    Also, my app does need the Internet Client capability, and removing that capability causes failure in recognition. So it it required and fails with an error of 'sorry, but we can't access the internet right now' when that capability is not there. However, if network access isn't available, but you have the capability, it will still work. I couldn't find this in the documentation, it was a trial/error exercise in determining the need.
    My apologies, I was by no means intentionally trying to be negative nor disrespectful. I just wanted to clarify that I had already tried the traditional approaches to solving the problem, which I why I reached out here.
    I'm trying to use the Dictation Recognizer but keep getting an completed unsuccessfully unknown error.
    I've ensured all capabilities and settings are correct.
    Microphone, InternetClient, and device privacy settings are all configured appropriately.
    Still getting this error.
    Stephen Hodgson
    Thanks for the tip, I'll have to try that approach. Using the WSA libraries doesn't allow this method to work in the Editor, seems there's a bug in the Editor libraries for this at the moment. I've already reached out to Unity to fix the problem.
    Stephen Hodgson
    Yeah I tried that but didn't get anything useful from Unity's unmanaged code.
    Stephen Hodgson
    I think I was really just interested to know if anyone else was having this issue so I could confirm it with Unity.
    Thanks for everyones responses.
    Stephen Hodgson
    Hi, Have a look at my Hololens tutorial on how to use dictation using the latest MR Toolkit (2017). https://codeholo.com/2018/03/17/dictationexamplehololens/
