Can I control the Hololens with a wired USB mouse?
I am able to pair a wireless / BlueTooth mouse with my Hololens and able to perform clicks, scrolls, etc. However, when I connect a wired USB mouse (via the microUSB port) to the HoloLens, it does not do anything. Given that Windows Holographic is based on Windows 10, I was expecting it to work as well. Is that expectation correct? Am I missing some setting that I need to do to make it work?
Thanks.
    Answer ✓
    The MicroUSB port on the HoloLens is only available for Charging and deployment. You cannot hook any accessories up to it at this point.
    Hopefully, maybe, in a future firmware update...
    Answer ✓
    The best way to provide that feedback is using the Feedback application on the HoloLens itself. If you don't have a device, you might try messaging @Vanessa or @Brandon to get that feedback logged
    I am able to pair a wireless BlueTooth mouse with my Hololens and able to perform clicks, scrolls, etc. However, when I connect a wired USB mouse (via the microUSB port) to the HoloLens, it does not recognize any clicks or scrolls done on the mouse. Given that Windows Holographic is based on Windows 10, I was expecting it to work as well. Is that expectation correct? Am I missing some setting that I need to do to make it work?
    Thanks.
    Answer ✓
    Maybe you can try with a bluetooth mouse
    Thanks Jesse.
    Do you or anyone have an idea when that firmware update may be available?
    Nope, Microsoft has not shared any sort of roadmap or anything like that with us
    Thanks Jesse.
    Are you aware of a contact I can reach out to? I think having a full fledged USB port will be very useful for multiple purposes to multiple people.
    Answer ✓
