How to call an API in the HoloLens?
Hey guys,
I am building an application to display stock quotes on boards.
When i run the application in unity the API data from the response is displayed on the boards, but when i build to the hololens there is no data on the boards. only the headers that i have hardcoded in there.
I have used the WWW and UnityWebRequest to do the API call so far but both gave the same result.
Anyone else bumped into this issue?
note: in player settings in unity, under the publishing settings, i have checked the following.
- InternetClient
- InternetClientServer
- PrivateNetworkClientServer
- Microphone
- SpacialPerception
Quick solution.
For example
changeWWW www = new WWW("http://10.10.10.12/test/");
toirequest++; WWW www = new WWW("http://10.10.10.12/test/?irequest=" + irequest.ToString());
Full example:
using System.Collections; using System.Collections.Generic; using System; using UnityEngine; using UnityEngine.UI; //using Newtonsoft.Json; public class APIRes { //[JsonProperty("result")] public int result; } public class Uptest : MonoBehaviour { public Text text; private float updateTime = 2f; private string results; private Coroutine _coroutine; private int irequest=0; private void Start() { _coroutine = StartCoroutine(CoUpdate()); } private void CollectResult() { Debug.Log("Collect: " + results); //Wont work on hololens see debug messages in Visual Studio APIRes res = JsonUtility.FromJson<APIRes>(results); //Worked - need JSon.Net //APIRes res = JsonConvert.DeserializeObject<APIRes>(results); text.text = res.result.ToString(); } private IEnumerator CoUpdate() { while (true) { results = ""; WebQuery(); yield return new WaitForSeconds(updateTime); } } private void WebQuery() { //Worked irequest++; WWW www = new WWW("http://10.10.10.12/test/?irequest=" + irequest.ToString()); //Wont work //WWW www = new WWW("http://10.10.10.12/test/"); StartCoroutine(WaitForRequest(www, CollectResult)); } private IEnumerator WaitForRequest(WWW www, Action onComplete) { yield return www; if (www.error == null) { results = www.text; onComplete(); www.Dispose(); } else { Debug.Log(www.error); } } }
5 -
Devc0n ✭
@jbienzms Thanx for the mention to check the messages aswell. i have searched to forum to make the debug window visible inside the emulator/device and i got a message that the InternetClient capability was unchecked. this needs to be check for using www. i had this done at first but then it got unchecked somehow (forgot to save file or something i guess.)
@pestantium thanx for the code example provided for my issue.
But everything is working now. If someone else is having the same issues as i had please see this post to get the DebugWindow inside of your application.
@Devc0n it appears you've done everything you should have done. Have you attached the Visual Studio debugger to see if there are any errors being logged or thrown?
Our Holographic world is here
@jbienzms Thanx for commenting on my question.
I have used the debugger in visual studio to watch for errors but sadly enough, nothing.... (also connected the debugger in the build settings of the project in unity).
The strange part for me here is that it does work in unity. but on the device or emulator nothing shows up on the boards. i have no idea why there would be a difference in those two.
Same here. Use a Unity 5.5.1f1. In editor it works fine but in runtime I get same response on WWW, Checked in Visual Studio in Debug mode.
Quick solution.
For example
change
to
Full example:
@pestantium Thanx for the example, i have used your format to create my request. but sadly enough still i am not able to see the data in the hololens.
also Debug.Log does not seem to work for the VisualStudio debugger on HoloLens? either this or the entire script does not start when the application runs in the hololens.
Here is the code i am using now (based on your example, works inside of unity)
The irequest variable used in the sample @pestantium posted is to get around HTTP request caching. It's interesting that only happens at runtime and not in the editor. If so, that must be due to how UWP handles requests under the covers and Unity's WWW class must use that stack when targeting UWP. That would make sense.
Sorry @Devc0n but I'm still at a loss as to why your code isn't working. I haven't had a chance to actually build your code and test it.
What happens when you run under the Visual Studio debugger after deploying to HoloLens? Is
www.error
still null? And what is contained inwww.text
?Our Holographic world is here
P.S. I want to make sure we figure out what's going on with the www class since it should work and since it is "Unity Portable". But if you are in a pinch, you can look at using the underlying HttpClient class. It's very powerful and fast, but it is UWP-only, which means you'll have to use conditional compilation in your code and deal with Async (which Unity doesn't understand).
If you want to or need to go down this path, you can look at the TextToSpeechManager class in the toolkit as an example of how to call UWP functions and deal with Async.
Can you try the following Unity package please? https://assetstore.unity.com/packages/tools/network/rest-client-for-unity-102501
