Public ip address in hololens Build
edited January 2017 in Discussion
Hi guys,
I want to get ip address using c#, in this case i have used 2 or 3 codes.
//code1
Network.Connect("http://google.com");
currentIP = Network.player.externalIP;
Network.Disconnect()
//code2
public string GetIP()
string externalIP = "";
externalIP = (new WebClient()).DownloadString("http://checkip.dyndns.org/");
externalIP = (new Regex(@\d{1,3}.\d{1,3}.\d{1,3}.\d{1,3})).Matches(externalIP)[0].ToString();
return externalIP;
//code 3
IPHostEntry IPHost = Dns.GetHostByName(Dns.GetHostName());
lblStatus.Text = "My IP address is " +IPHost.AddressList[0].ToString();
All codes gave me ip address successfully but the problem is that whenever i Build it on hololens the unity editor gave me error.
Please help me to solve out the problem. I want to get ip address on hololens without complexity of errors.
    what exactly are you trying to achieve here? public facing IP?
    WoliarkWoliark
    edited February 2017
    @Waqarahmed Hi!!! I managed to get the Ip adress of an hostname but i could only test this code within the hololens emulator due to some issue with my network. This code only work outside unity
    //#if !UNITY_EDITOR
        using Windows.Networking;
        using System.Threading.Tasks;
        using Windows.Networking.Sockets;
    //#endif
    //#if !UNITY_EDITOR
        async Task GetIPAdressFromHostname(string sHostname, string sPort)
            string  sRemoteHostName = "",
                       sLocalHostName     = "";
            HostName host = new HostName(sHostname);
            var eps = await DatagramSocket.GetEndpointPairsAsync(host, sPort);
            foreach (EndpointPair ep in eps)
                sRemoteHostName = ep.LocalHostName.ToString();
                sLocalHostName = ep.RemoteHostName.ToString();
                System.Diagnostics.Debug.WriteLine(sRemoteHostName + " : " + sLocalHostName);
            //DO THE THINGS....
    //#endif
    #if !UNITY_EDITOR
    //#endif
    //#if !UNITY_EDITOR
        //DO THE THINGS....
    #endif
    #if !UNITY_EDITOR
    //#endif
    //#if !UNITY_EDITOR
        //DO THE THINGS....
    #endif
