Upgrade Current Laptop or Buy New One?
Hi Everyone!
Since I don't have a hololens, I plan on using an emulator to start building holographic apps.
I've read the system requirements for running a hololens emulator as stated here.
However, I still need some help in deciding on whether to upgrade my current system or invest in a new one.
My laptop:
- CPU: Intel(R) Core(TM) i3-3110M CPU @ 2.40GHz (2 cores, cache size 3MB)
- RAM: 4.00 GB
- OS: Windows 10 Home
- GPU: Intel(R) HD Graphics 4000
Here are some facts:
- The RAM can be upgraded to 8.00 GB.
- The graphics card supports DirectX11 and it's integrated to the motherboard and cannot be replaced with a better card.
- I am not sure if it uses a WDDM 1.2 driver (or later).
- I don't know if the BIOS is capable of SLAT and DEP.
Question:
Should I upgrade to Windows Pro, which I assume my system will support, and increase its RAM to 8GB, or is it best to invest in a more powerful system?
Thanks in advance!
Mike
andrha ✭
To check the WDDM driver supported by your card, run DxDiag. In the tabs, select Display 1. Under Drivers should show your supported WDDM.
From the linked requirement on bios requirements, note the following for intel CPUs:
- For SLAT: "Intel refers to this a Extended Page Tables (EPT) "
- Unfortunately, I couldn't determine if DEP was enabled for your processor, but it looks like SLAT is. You can find more at ark.intel.com/products/65700/Intel-Core-i3-3110M-Processor-3M-Cache-2_40-GHz
