Couldn't auto-detect the guest system IP address.
edited February 2017 in Projects
I'm getting this error when I try to start my HoloLens Emulator. I have tried everything, from reinstalling Hyper-V, tinkering with the Virtual Switches, and have also tried all the methods mentioned in this link : https://forums.hololens.com/discussion/1100/how-to-fix-hololens-emulator-connectivity-issues.
It still doesn't work. Any suggestions?
Regards,
Pranav
    Solved it. Turns out I missed one of the steps mentioned in the link attached with the question. Rookie mistake
    Can you tell me how to solve this problem?I have the same problem.And now I have no idea.I have set the "Inter Virtualization Technology" enable in BIOS.But when I use cpu-z to check the instruction set,there're no vt in it.It's terrible…
