How is it possible to programmatically save a data file to an FTP site?
I have looked at this a lot and really can not find a way of doing it yet. I am sure someone out there can advise me of a better way of approaching this.
It seems that FtpWebClient is not available under Unity so it is a bit difficult to send datafiles to an FTP site. I am not clever enough to see a way around this. Also GoogleDrive seems elusive as the sample given from https://github.com/midworld/unity-googledrive
appears not to work for the PC. The link for PC and IOS in this document leads nowhere. Of course I have looked at OneDrive too (the much preferred option for HoloLens) and I did not find an solution there either.
What I want to do is program some c# code with the correct ID and credentials to send a file to another place during using the Hololens. The idea is to have it commanded by voice and not have any had gestures associated with it. I would take any solution - OneDrive/GoogleDrive/FTP/Amazon I don;'t mind as long as it is independent storage for my data,
Please tell me if there is a way to do this.
Many thanks.
    Build a WinRT Component and leverage that using Unity.
    Dwight Goins
    http://dgoins.wordpress.com
    wheelchairmanwheelchairman ✭✭
    Answer ✓
    Thanks Dwight, I'll give that a try (if I can work out how to do it).
