Limiting Fov
I was wondering if it is possible to limit the fov further, to improve placement/highlighting accuracy. Currently I see that it we get: 1280x720 (pixels) with a 45deg fov on the default mode. I was wondering if one can get 1280x720 with a 22.5 deg fov or not.
OptionsLeweyGeselowitz mod
If your goal is to lower the number of pixels rendered, you can use an off-screen render target that has a lower FOV and then re-project that back into the scene. I did this in early prototypes to allow pixel-heavy volume rendering. You need to do the following:
- Setup a Unity RenderTarget,
- Setup secondary Camera (that moves with the main camera, updates to the Render Target and has your smaller FOV)
- Scale and project/texture the RenderTarget back into the world.
This effectively gives you a lower-resolution virtual screen that floats in front of the user.
Are you using unity? Obviously, the FOV is fixed on the actual hardware itself. However, the camera is Unity has a FOV adjustment you can make.
What I want is to be able to get 1408 (on the high camera settings) with a 45deg FOV instead of the 48deg, to improve resolution and be able to identify small objects.
Doesnt really matter on the unity side, it is the actual camera that I would like to be able to configure.
I see, I'll let one of the admin answer, but I'd be surprised if the actual hardware is that configurable.
