New app is black on the emulator
Dear WHDF ,
I played around with the MS 101E tutorial and now want to develop my own app POC app for fun. I already made an asset and copied the lights and cursor from the 101E project.
However when I want to launch the app the screen is black as seen in image 1. While when I look at the camera of unity it clearly displays my own created asset as seen in image 2
What am I doing wrong? If I launch the 101e app it works so it cannot be a GPU or other related problem to the hardware. I even followed the same steps as in the 101e tutorial but only didn't use their assets.
I hope someone can help me "See the light"
Kr.
Tvt
PS: i did not implement the WorldCursor yet.
OptionsTvt ✭
@james_ashley I just redid everything but used the Project files of the 101e demo and it works without any problems. Would say that it's eater something I did or a bug somewhere when you create your own project with the newest unity.
Hi @Tvt,
Your camera settings are wrong. "Clear flags" should be set to "solid". Background should be black (0,0,0,0) which is the transparent color value in HoloLens.
@james_ashley thanks for spotting that error. But unfortunatly the screen is still black
@Tvt,
Can you get other apps to run in your emulator? Have you fiddled with the desktop acceleration settings? Is the box inside your clipping range or outside it?
@james_ashley I was able to run the example perfectly and without any problems. So that's why I know that there are not any problems with the hardware acceleration of the GPU or something else because then it would not have worked in the first place.
@Tvt,
Sounds right. Probably was an error that prevented everything else from loading. Glad you got it worked out. (Secondarily, would still recommend getting it working with the HoloToolkit if you can. This is more standard and more powerful, in the long run.)
@james_ashley
i am working with the holotoolkit right now. and it works with the project I created. might be better for new people to do the 210 tutorial since they cover how to make your own project from scratch:
https://developer.microsoft.com/en-us/windows/holographic/holograms_210
