Prevent HoloLens from going to sleep
Is there a way to disable HoloLens from going to sleep. On device portal, I can only choose when will HoloLens go to sleep, but I cannot disable it.
I have a problem because it goes to sleep while my application is active.
    I believe (though I'm not positive) that the device will not sleep when the Visual Studio debugger is attached. I understand it is going to sleep while your application is active, but are you saying it's going to sleep when someone is using the device? That shouldn't be happening. If you're saying it's going to sleep when they take the device off and set it on the table, that's by design. Is there a reason you don't want this to happen?
    Our Holographic world is here
    DaTruAndiDaTruAndi ✭✭
    edited February 2017
    In the device portal you find the following settings.
    Sleep settings
    When on battery, go to sleep after
    When plugged in, go to sleep after
    By default that is
    2 minutes, 3 minutes, 5 minutes, 10 minutes, 20 minutes, 30 minutes.
    I believe you can "hack" the corresponding seconds (see below) in the "inspect" mode of the browser (or set it through code) to other values.
    I set it to "0" for fun (when plugged in) and I BELIEVE it does not go to sleep now.
    2 minutes3 minutes5 minutes10 minutes20 minutes30 minutes
    It does not go to sleep while debugger is attached, and it also does not go to sleep while someone is using it. But as you said it goes to sleep while it is on the table.
    I don't want it to go to sleep because it is connected to my server and sending data, and I am doing tests on server application and need HoloLens to stay awake.
    @DaTruAndi
    Thank you for your answer. I will try your method.
    @Xarthisius Did that work for you?
    yes, it works
    edited May 2017
    http://127.0.0.1:10080/api/power/cfg/SCHEME_CURRENT/SUB_SLEEP/STANDBYIDLE?ValueAC=0&ValueDC=0
    http://127.0.0.1:10080/api/power/cfg/SCHEME_CURRENT/SUB_SLEEP/VIDEOIDLE?ValueAC=0&ValueDC=0
    after testing, it's the above post request that will set the hololens to "non-sleep" mode.
    Above is what you should have after the configuration is set successfully(you have to login first and then send this request, you may consider using postman)
    try these two post requests after connected to your hololens.
    JayZuoJayZuo mod
    edited January 2018
    The following is one easy way to prevent HoloLens from going to sleep when it is plugged in.
    1. Log into Windows Device Portal.
    2. Press F12 to open Developer Tools on this page.
    3. Select Console in Developer Tools.
    4. Use Fetch API to send the following two post requests.
    fetch("/api/power/cfg/SCHEME_CURRENT/SUB_SLEEP/STANDBYIDLE?ValueAC=0&ValueDC=180", {
        method: "POST",
        headers: new Headers({
            'X-CSRF-Token': document.cookie.match(new RegExp('CSRF-Token=([^;]+)'))[1]
        credentials: "same-origin"
    fetch("/api/power/cfg/SCHEME_CURRENT/SUB_VIDEO/VIDEOIDLE?ValueAC=0&ValueDC=180", {
        method: "POST",
    Here we are actually using WDP REST API. ValueAC represents setting when plugged in and ValueDC represents on battery. When it's value set to 0, it means never go to sleep.
    Please note it's not recommended to set ValueDC to 0 and you should only set ValueAC to 0 when you really needed.
