How to see what the hololens is doing in the developer portal
At build i was told you can see what the hololens is displaying through the developer portal. Is this true? If so can you tell me where this is with in the developer portal. I am unable to locate it.
Thanks
Calzaretta
I found this after a bit of digging.
https://developer.microsoft.com/en-us/windows/holographic/Using_the_Windows_Device_Portal.html#Connecting_over_Wi-FiThanks for putting me on the correct track with what to search on.
You can see more about mixed reality capture here.
More specific to your question, to use mixed reality capture from the developer portal please see the following page: https://developer.microsoft.com/en-us/windows/holographic/using_mixed_reality_capture
I get a bad request trying to sign in to that wiki. Can you paste the info in this form?
Thanks
Chris
Hey @Calzaretta, I updated the links provided by @andrha, so you should be able to access them now. Thanks!
