Hololens and iPhone
AR123
Does anyone know if you can write a Hololen app to interact with an iPhone app?
ahillier mod
You should be able to design a network solution that can work between HoloLens and a phone (try HoloToolkit Sharing component), but Bluetooth is not currently an option (there is no way to pair a phone to the device right now). https://developer.microsoft.com/en-us/windows/holographic/working_with_accessories#Other_Bluetooth_accessories
7
Interact in what fashion? You can always design your application to communicate to an iPhone over the network, or depending on the type of interaction (close) then bluetooth.
@AR123 adding to what @Jarrod1937 said, an example would be that the HoloToolkit's sharing libraries are designed to be cross platform:
But as Jarrod1937 pointed out, the question then becomes what do you want to do with a connection to a platform that doesn't have the Windows Holographic api support?
It is possible, and supported, but you will need to create a scenario or potentially libraries to support something of value and interesting on the iPhone that makes use of things like the World Anchor information that gets shared.
Awesome stuff @HoloSheep @Jarrod1937
I guess what I’m curious to know is can an app be made on the Hololens to visually ping you (i.e. show a persons dating profile from Tinder) whenever that person is near you? …or if someone fits a criteria on LinkedIn that you are looking for and walks by you?
I see, that would require localizing/position tracking of an arbitrary device, which is a bit more complicated. Within a certain distance iBeacon may work:
https://en.wikipedia.org/wiki/IBeacon
But that's assuming an app on a phone can act as an iBeacon, that I'm not entirely familiar with.
I have make a demo app ,control with iPhone.
I'm using OSC message via UDP.
@littlewing That's awesome! Good work...can I hire you? haha
@littlewing
Are you using unipad for unity asset? But I build in Windows Store platform get CS0246 error.
@decem
Thank you for your interest.
As you say,it does not work well as it is.
I have developed a OSC-library that works on UWP(Hololens).
https://github.com/littilewing/UnityOSC-HoloLens
You have to replace Uniy-OSC in the assets with this.
Please try it if you have a time.
Hey @littlewing, thanks for UWP! Wonderful work!
I've tried to use your repo and probably I am doing something wrong. I've tested on my local machine and it works fine. When I'm trying to run on Hololens it doesn't work. I will really appreciate if you guide me somehow.
Hi @littlewing Your video Car Showroom with HoloLens -demo
is really amazing
Thanks
@Gordey sorry for the late reply .i have fix some wrong code.please try it.
https://github.com/the6th/UnityOSC-HoloLens
