How to make Vumarks work in Hololens
Hello,
I am trying to make the Vumark works in my own project. I use the Morton marker and made my own database and license key. I follow the Vuforia development overview settings. The project deployed successfully but I don't know why it shows nothing on the screen. I add the cursor but it doesn't show up either. The front camera of Hololens indicator is on. I don't know why it is nothing shows up? Who can help me please!
I'm not sure if its related but you may want to fix the null references in the output there first. It may be why the cursor is not showing up.
Hi mark_grossnickle,
Do you know how to fix it?
Well the log says there is a null reference at line 208 in the Cursor class. If you look there it is referencing the gaze manager. Do you have the InputManager prefab in your scene?
