HoloLens companion app
MattZ
admin
Feedback and bug reporting for Microsoft HoloLens companion app, available from Windows Store on PC and Phone.
I got a Hololens and it works great. How can I stream live video from it that includes the holograms? Skype works but it removes all augmentations besides the skype window.
This is the wrong place for that question, better put in Q&A, but if you open the device portal, there's a tab that will let you take pictures or videos that give the view from the HoloLens.
Actually the companion app lets you do that, too. I found however that for (unknown reasons) the streaming through the device portal seems to be more stable than the companion app.
But "live" is not true in my experience. For me it was about 6 seconds delay.
I don't know about other people's experiences, but the video streaming only works for the first minute or so, then eventually slows down and stops. This is true for any of the three quality settings. If I change the quality setting, then it resets and I'm good for a little longer.
I have not had any issues with the video streaming, other than the fact that there is a delay from what I see through the headset, and what the person watching sees. It seems to be a 6 to 10 second delay.
Does anyone know what the true resolution of the stream is? Obviously it scales to fit the window.
truthlabs.com | @_DANTHOMPSON
Depending on network quality (I think), it can have a delay up to 6 seconds - but sometimes I see about 1 second or less, which is awesome.
Please add the ability to set the IPD in the app.
It'd be great to have the performance monitors (especially FPS) meter as well. Otherwise great job, I prefer it to the device portal!
In an answer to my own question: The answer can be found in the device portal...
Sounds like I can accomplish anything I need to using the device portal but wanted to get the Companion App working just to see it Since nobody else seems to be having an issue I must be doing something wrong.
Figured out that I needed to set a password on device portal, check!
Restarted device and computer (just in case)
Entered IP and creds created in device portal, no go. CApp reports: .
"Device Unreachable"
CApp must see my device because I get a different error (pinwheel) when changing to bad IP. I believe for some reason it's not taking un and pwd, I also get same error when entering invalid creds.
-Device Portal on, Dev mode enabled on device
-deviceportal using device IP works great
-tried ResetCredentials in CApp which does change the password (confirmed in device portal) but logging in generates same Device Unreachable afterwards
Picky stuff
Noticed pwd is displayed as plain text instead of **** on CApp. UI
After resetting password using CApp, should probably redirect UI to login screen or show confirmed message
N6MAA10816
I blogged about how to use the live preview API here: https://medium.com/truth-labs/how-to-share-your-reality-with-the-rest-of-the-world-22cea52ec07#.3hucuowfk
