Running emulator gives error "Failed to load SKU: "HDE": There is an error in XML document (0,0)
I am running a windows 10 VM on my Macbook Pro (Yosemite) inside Vmware Fusion. There is enough memory I have allotted to the VM and enough space. When I try to launch the emulator, I get this error while running it from Visual studio as well as from the Powershell using the command :
C:\Program Files (x86)\Microsoft XDE\10.0.14393.0\XDE.exe” /name “HoloLens Emulator 10.0.14393.0” /displayName “HoloLens Emulator 10.0.14393.0″ /vhd “C:\Program Files (x86)\Windows Kits\10\Emulation\HoloLens\10.0.14393.0\flash.vhd” /video “1268×720″ /sku HDE
THis problem got solved, I uninstalled and installed the Hololens Emulator again, and it worked.
