[SpectatorView] Calibration always fails
I have tried to calibrate my camera and HoloLens with Calibration.sln using Visual Studio 2015 Update 3
I have downloaded the whole HoloLensCompanionKit-master from GitHub, change dependencies.props and stdafx.h. Calibrations app starts, it make some photos with chess board, but when I press enter trying to create CalibrationData.txt CalibrationApp always fails on line 383 of CalibrationApp.cpp:
// Calibrate the individual cameras. cv::Mat distCoeffColor, distCoeffHolo; cv::Mat colorR, holoR, colorT, holoT; cv::Mat colorMat = cv::initCameraMatrix2D(colorObjectPoints, colorImagePoints, cv::Size(HOLO_WIDTH, HOLO_HEIGHT), (double)HOLO_HEIGHT / (double)HOLO_WIDTH); ==> cv::Mat holoMat = cv::initCameraMatrix2D(holoObjectPoints, holoImagePoints, cv::Size(HOLO_WIDTH, HOLO_HEIGHT), (double)HOLO_HEIGHT / (double)HOLO_WIDTH);
Finally Calibration project crashes with error "opencv_world310.pdb contains development information, necessary to find the source code of opencv_world310.dll"
How i can fix this?
My files:
dependencies.props:
<?xml version="1.0" encoding="utf-8"?> <Project ToolsVersion="4.0" xmlns="http://schemas.microsoft.com/developer/msbuild/2003"> <ImportGroup Label="PropertySheets" /> <PropertyGroup Label="UserMacros"> <!-- From: http://sourceforge.net/projects/opencvlibrary/files/opencv-win/3.1.0/opencv-3.1.0.exe/download --> <OpenCV_vc14>C:\opencv\build\x64\vc14</OpenCV_vc14> <!-- From: https://www.blackmagicdesign.com/support --> <DeckLink_inc>C:\Blackmagic\Blackmagic DeckLink SDK 10.8.3\Win\include</DeckLink_inc> <!-- From: https://github.com/elgatosf/gamecapture --> <Elgato_Filter>C:\Users\HoloGroup\Documents\GitHub\gamecapture\VideoCaptureFilter</Elgato_Filter> </PropertyGroup> <PropertyGroup /> <ItemDefinitionGroup /> <ItemGroup /> </Project>
stdafx.h:
// Copyright (c) Microsoft Corporation. All rights reserved. // Licensed under the MIT License. See LICENSE in the project root for license information. #pragma once #define CHESS_SQUARE_SIZE 0.0677 // Width of the chess squares in meters = 2.66 inches. // Note: must have > 3 columns and rows. #define GRID_CELLS_X 6 // Number of columns in the chess board. #define GRID_CELLS_Y 4 // Number of rows in the chess board. // NOTE: If you change this to the HoloLens IP, you will need to: // 1. Under the Security tab in the developer portal, disable SSL connection. // 2. Use http://%DEVICE_IP%/ - do not use https:// #define HOLOLENS_ADDRESS L"http://127.0.0.1:10080/" #define HOLOLENS_USER L"Hologroup" #define HOLOLENS_PW L"Holo123456" // Color feed from Hololens. #define HOLO_WIDTH 1408 #define HOLO_HEIGHT 792 #define HOLO_BPP 4 // RGBA #define HOLO_BUFSIZE (HOLO_WIDTH * HOLO_HEIGHT * HOLO_BPP) #define CALIBRATION_FREQUENCY_SECONDS 3 // Use the C++ standard templated min/max #define NOMINMAX #define WIN32_LEAN_AND_MEAN #include <windows.h> #include <wrl/client.h> #include <d3d11_1.h> #include <DirectXMath.h> #include <DirectXColors.h> #include <algorithm> #include <exception> #include <memory> #include <stdexcept> #include "Keyboard.h" #include <ScreenGrab.h> #include <wincodec.h> #include <string> #include "CompositorShared.h" namespace Calibration { namespace DX { // Helper class for COM exceptions class com_exception : public std::exception { public: com_exception(HRESULT hr) : result(hr) {} virtual const char* what() const override { static char s_str[64] = { 0 }; sprintf_s(s_str, "Failure with HRESULT of %08X", result); return s_str; } private: HRESULT result; }; // Helper utility converts D3D API failures into exceptions. inline void ThrowIfFailed(HRESULT hr) { if (FAILED(hr)) { throw com_exception(hr); } } // Safe release for interfaces template<class Interface> inline void SafeRelease(Interface *& pInterfaceToRelease) { if (pInterfaceToRelease != NULL) { pInterfaceToRelease->Release(); pInterfaceToRelease = NULL; } } } }
Jackson mod
Do you have images for both your camera and your HoloLens in "Documents\CalibrationFiles"? You should see matching pairs of files #_cam and #_holo. Ensure that you have at least 1 pair where the entire checkerboard is visible.
Note: when you relaunch the calibration sln, all of your files get copied to "Documents\OldCalibrationFiles" - After you launch, you can copy them back to CalibrationFiles if you want to recalibrate with the same files.
You can also put a breakpoint on line 382 and verify colorObjectPoints, colorImagePoints, holoObjectPoints, and holoImagePoints all have at least 1 element.
1
Finally I figured out what I done wrong, I found a silly mistake in stdafx.h file, that was wrong user login or pass, сonsequently I had only photo from cam.
For now I calibrated it in proper way, thank you a lot
