Continuous Spatial Mapping Updates
I am trying to keep updating the spatial mapping mesh as a user walk around. I am using the SpatialMappingManager/Observer from the toolkit. I don't want to be bound by the following property
[Tooltip("The extents of the observation volume.")] public Vector3 Extents = Vector3.one * 10.0f;
I don't need to maintain all of the data as the user walks around, I just want to allow them to change locations and continue to use the mesh.
I suppose I could keep adding, or possibly re-instantiate, but it seems like there should be an easier solution.
To say this differently, the docs state I just need to recall the setVolume method. What is the most reliable way to determine when to recall the setVolume?
Hello RobAllen,
I am trying to do exactly the same. Did you find the solution for your problem?
Best,
mkop
