How to create and write to .txt file
How do you create a .txt file which we can then use to write information about the users position to.
http://answers.unity3d.com/questions/279650/create-text-file-in-c.html
The following code will write to your application's local folder where you have write and read access. another plus is you know the exact path when you load it at run time.
//Get local folder StorageFolder storageFolder = ApplicationData.Current.LocalFolder; //Create file StorageFile textFileForWrite = await storageFolder.CreateFileAsync("Myfile.txt", CreationCollisionOption.ReplaceExisting); //Write to file await FileIO.WriteTextAsync(textFileForWrite, newFile); //Get file StorageFile textFileForRead = await storageFolder.GetFileAsync("Myfile.txt"); //Read file string plainText = ""; plainText = await FileIO.ReadTextAsync(textFileForRead); Debug.Log("New file written: " + plainText);
if you want to access the streaming assets folder at runtime from the hololens you can also do this
StorageFolder dataFolder = await Windows.ApplicationModel.Package.Current.InstalledLocation.GetFolderAsync("Data"); StorageFolder streamingAssetsFolder = await dataFolder.GetFolderAsync("StreamingAssets");
then you can call GetFileAsync() to get a file you have there (I am unsure about being able to write there which is why I write my file to the LocalFolder)
